ORIGINAL: TopShelf
Hello all,
I'm having a moment of intellectual denisty. I can't seem to figure out how exactly to install the fan on the Mirage. It is different from the way it installed on my Kamdax MIG-15. Everything I come up with does not seem to make sense. Does it just screw into those flimsy plastic things that fit into the fuse? My instructions say that these don't get glued so that does not seem like it would keep the fan in place.
Anyway, any help would be appreciated.
The mounts DO need to be glued in. Rough them up and drill some holes and epoxy them in. You need a small slot in the foam above them, if you look closely, there is a marking on the foam. After that, the fan slides in, it does NOT need to be screwed, the plastic tabs hold it.
What are you using, gear-wise? Lighter is better.
