Good morning. I have a Futaba EXA. Last night I was working on my plane and went to turn on my EXA to check the servos. The throttle stick on the transmitter has somehow "binded up". It is very stiff and requires force to move. If you move the throttle up and let go of it, it springs back down to idle. At first I thought it was the throttle linkages within the plane so I checked that. I turned the radio and plane off and the stick is still stiff. I switched to another radio and everything works properly. Right now the EXA is partially disassembled and I'm hoping to find that a wire or something is wedged in where it shouldn't be causing this problem.
Has anyone else experienced this and what was done to resolve it ?
Thank you, DJJ [
