RE: CG location for a Byron Hellcat??
the location is easy to find, look on each side of the fuse there should be one small indent on each side of the fuse, about half way down and behind the trailing edge of the wing, drill a small hole where the indent is, hang the plane using the small hole location, don't forget to balance with the gear up.
Pierre
