RCU Forums - View Single Post - NEED AERONAUTICAL ENGINEER FOR PATENT/PLANE/ENGINE DEVELOPMENT
Old 07-29-2005 | 09:02 PM
  #34
EASYTIGER
Banned
My Feedback: (119)
Default RE: NEED AERONAUTICAL ENGINEER FOR PATENT/PLANE/ENGINE DEVELOPMENT
ORIGINAL: Kevin Greene
ORIGINAL: Gordon Mc
Seems to me that the easiest way to achieve that, is have an outer skin - so the insulating foam is kept between skins. I gues sthat would probably be a tad too heavy tho...
Gordon--You and I are on the same page--I was thinking about this very thing today and thought that a tough, rubberized polymer applied in a VERY thin coat might do the trick--As you stated, it would have to be kept very thin to keep the weight down. I'm sure that the NASA engineers will come up with something.....After all, this same type of problem solving at NASA brought us some of the high tech materials that today are common occurance.[8D]
Woketman--Did the originator of this thread ever contact you????
Kevin
Something like...Monokote? Man, that would be EXPENSIVE.
