Sig Hog Bipe
Mount the gear 1/2" to 1" forward of the normal spot. Make a bigger, thicker gear mounting plate if you like, you'll appreciate it later on.
Don't cheat on the CG. Make sure it's at their suggested location or up to 1 inch forward.
Have plenty of elevator throw (maybe 2" overall) and damp it down with dual rates or expo. You'll need a lot of throw to flare at a low speed.
Glue washers to the wing struts before covering. Without washers the little 4-40 screws will go through that lite ply pretty quickly.
If this is your first bipe, have someone else with experience do the maiden.
What engine are you planning to use?
