rush probs
my rush is driving me insane. i am struggling to get everything right with it. the main problem is it seems to be on constant brake. should there be a spring to bring the brake bar back. when you brake the servo rod with spring and screw end pull in and turn that bar thing so i squeezes the brake together which is fine but when youput throttle on the servo bar comes off the brake but the bar thing remains in the same position so its brakin slightly. plus whenit does brake the servo rod aint pullin it in much further so its not brakin much harder than when on normal.
also despite playin with the hsn it goes and then cuts out
oh and goes on its own
grrrrrrrrrrrrhhhhhhh
