Ultra Stick 40 Vertical Stabilizer
The instructions for the Ultra Stick say to just remove the covering from the rear part of the vertical stabilizer and epoxy it into the pre-cut slot on the fuse. Is this enough surface area to hold the vstab securely, or should I also remove the covering on the fuse that would fall under the rest of the length of the vstab??? Also, with the vstab in the precut notch it looks like it angles toward the right a bit, not true center.
Anyone who has built one of these have any input? Or am I just being paranoid about this build?
