RCU Forums - View Single Post - Help with inverted engine
Old 07-31-2005 | 07:08 AM
EXTRA ADDICT
Default RE: Help with inverted engine
You could get yourself a Cline regulator. Then not only would your flooding problem be solved but you can move the fuel tank back to the CG. Then your CG will not change during flight as you burn fuel. The regulator is only about 50 bucks and very easy to install.
