RE: Esky honey bee CP
Thanks paedbo, I new you would come to the rescue!
Quote:
>> your going to have to take apart the 4 in 1 box to hook up the HH gyro,
the tail signal from the receiver goes directly into the mixer board thats inside the 4 in 1 box.
You need to tap into the signal at this point where channel 4 comes off the receiver. <<
So, do I bypass the mixer on channel 4 by pulling the pins up on the 4-and-1 receiver board and
connect the gyro to those pins. (channel 4 pins will not be connected to the ESC, gyro mixing board)
I don't beleive I will need tail mixing since it's HH gyro, right?
Novak
