RCU Forums - View Single Post - For the engine builders: a simple prop driver?
Old 07-31-2005 | 02:30 PM
SERCEFLYER's Avatar
SERCEFLYER
Default For the engine builders: a simple prop driver?
This one is for the engine building gurus...
Ok, I've been trying to find a way to make a simple prop driver without turning a taper in the crank shaft and the prop driver. I found this old plan for the "Little Dragon" that seems to solve the problem. What's the disadvantage of making a prop washer as described in these plans?
