RE: Seagull Zero ground handling
I have been looking at this thing again and now think that there may be tow-out instead of toe-in causing my stability issues, I am gonna crank some toe-in and see how that works.
The way the wire legs mount to the wing, it induces a toe-out, looks like they may have to be bent before installation. I brought the main gear closer together, it is now 18 inches apart, it also looks a lot closer to scale spacing but I now have a feeling that toe-in is the real culprit.
I will update the results of the taxi tests in case this will help someone else.
Denny
