RCU Forums - View Single Post - Engine problems!
Old 07-31-2005 | 10:31 PM
ckangaroo70's Avatar
ckangaroo70
My Feedback: (51)
Default RE: Engine problems!
ORIGINAL: mitch1561
I'm out in the middle of no where, and nobody else is on the same channel. I can pretty much rule out someone else in the area on the same frequency. So as you can see, I've already thought about most of the obvious causes, except that I am on channel 52. I've heard 2 separate people tell me now that for some reason channel 52 has problems.
IMO radio hits are not that common as some may have you believe. When a Plane gets drilled into the ground IMO it is just too hard for some pilots to admit to themselves that a case of dumb thumbs crashed the Plane. So after alot of crashes you will see alot of excuses being made, and a "Radio Hit" is usually one of them that tops the list. I am not saying that it don't happen. I am just saying that I would bet it don't actually happen very often unless someone right at the field accidentally turns on a Transmitter that is on the same freq which is certainly a radio hit.
