RE: EP1 tunnel project
Great looking boat. My only comment is regarding the ESC cooling fan. It's not going to do much good when you seal the hatch. Even if you had a working snorkle scoop for fresh air intake, your fan is sitting right in front of the battery pack which will create a lot of heat on their own. Water cooling is the only way to go for ESC's. Get (or make) a water cooled heatsink instead. You'll be happier.
