RCU Forums - View Single Post - AMT Pegasus SP spool up ???
Old 08-01-2005 | 09:49 AM
Ray Davis
Default RE: AMT Pegasus SP spool up ???
Well...if it was the first run-up to max RPM that was so slow...that is normal. AMTs take a few seconds to calibrate max RPM each start, so if you want the fastest response (fast spool) on that TO...make sure you run it up to max beforehand. You'll see 'Max RPM Set' on the EDT.
Ray
AMT USA Field Rep
