RCU Forums - View Single Post - pipe for 18cv-rx and glitching
Old 08-01-2005 | 09:55 AM
Bax
Default RE: pipe for 18cv-rx and glitching
We'd have no idea how a flywheel, that's "hard-mounted" to the engine can cause any kind of glitching...unless the receiver antenna's either been cut down or is improperly-routed and too close to the engine. You need to check your R/C equipment. Glitching isn't caused by the engine, other than the vibrations shaking something loose. You may also wish to consider a failsafe.
The stock pipe is fine, and will help the bottom end a bit.
