RCU Forums - View Single Post - Too much engine for Hog Bipe??
Old 08-01-2005 | 10:45 AM
AnthonyH's Avatar
AnthonyH
My Feedback: (16)
Default RE: Too much engine for Hog Bipe??
Ken, as I stated I HAVE a TT 91 FS with the 15x4W APC and it HAS unlimited vertical. I was not asking if it would, I was stating that it does. You are correct in stating that the 91 4-stroke is not overpowering it, but with the right 91 and right prop you can achieve unlimited vertical if your build is light. A 91 4-stroke is probably the perfect engine for this plane. Trying to put a 120 on it would require some weight in the tail and/or moving the firewall back to get the balance right. The Saito 100 would be the largest engine I would consider since it is as light as a 91.
ORIGINAL: RCKen
ORIGINAL: AnthonyH
I have the TT 91 FS and like the 15x4W APC. Unlimited vertical!
No. You're definitely not going to get unlimited vertical with a 91 4-stroke. My OS 90 4-stroke is a great motor for this plane, but it's not overpowered like that.
Ken
