HELP Smith Mini Plane Torgue Rolls
Add couple degrees right thrust to engine, build speed before lift off,use a slow lift off,also might try 11x5 or 11x5 prop,I prefer APC,they have a better bite and the pitch is correct,p factor wants to pull left on hard take off,use right rudder to keep things headed in the correct direction.I have small ultimate bipe,using the same engine, so that is the best information I can give.
