ORIGINAL: Barry Cazier
Hopefully I can spend some time tonight and try the 16.5x5W again tonight. I'm pretty sure my RPM won't change but I'm also pretty sure my thrust will be up. I have two of these props I will try and balance the other one and test it. Let's don't start an argument.
Barry
Here's what Dave is Advertising about the 16.5 x5W for load.
http://www.rcuniverse.com/forum/m_32...tm.htm#3220462
I am thinking about ordering a couple of the 16.5 X 5W APC props for the YS110. My YS110 turns a 16 x 6 apc ~ 9,400 what would RPM you expect the 16.5 x 5W to spin?
"Should run about the same rpm depending in your engine, or maybe a couple of hundred less. Try it, they work well. "
