RE: Engine problems!
question. When you test out the plane on the ground is the wing mounted on the plane or is it off to the side so you have access to the inside of the plane. I was wondering if you have clearance for the controls to move when it is mounted tightly on the aircraft. It is hard to figure if I am not there. Is the servo good no broken gears or anything
