RCU Forums - View Single Post - AMT Pegasus SP spool up ???
Old 08-01-2005 | 06:24 PM
c/f
Default RE: AMT Pegasus SP spool up ???
Thanx for the input guys, I am going to view my pump volts allot closer this thursday on the standard Peggy in the Kingcat. Seems to me that 3 volts is more common. It may be worth a day in a jar for breakin. I also will view uat in KC for deformation. Not quite sure on this since I was certain to have 5/32" ID fittings on tanks.......hmmm
I'll try the bypass cover off........
Aslo I'm using Tams included exhaust tube mated to the BVM Bypass, and now that I think about it there is no flow for air thru the double wall Iguess this is OK???
