RCU Forums - View Single Post - gas fuel with glo plug no ignition
Old 08-01-2005 | 07:59 PM
  #206
RysiuM's Avatar
RysiuM
Default RE: gas fuel with glo plug no ignition
ORIGINAL: RysiuM
I will buy APC 16x4W that should unload the engine over 9000 rpm (I hope).
Nope I just tried APC 16x4W. Engine unloads to 8100 rpm. That's it. Calculated HP it has much less than with bigger prop. I guess, I just hit the rpm limit set by porting timing or ignition timing. That puts APC 17x6 on the top of all APC prop for this engine. I mean for thrust, not speed.
However good news is that I was still able to start the engine by flipping the prop. Setup the same as the last time: glow plug powered from 1.2V NiMh, gasoline with Motul oil 1:32
RysiuM
