RE: Ultracote Plus ?
Ultracote plus was used primarily as a trim material and for foam surfaces. It has a sticky backing and was easy to stick down and position on regular ultracote. You then used a warm iron to permantly seat it. The small 4" wide rolls of trim material they call Ultratrim is the same stuff. I don't believe Ultracote plus is still available but I may be wrong, I haven't seen it in some time.
