RCU Forums - View Single Post - AMT Pegasus SP spool up ???
Old 08-01-2005 | 08:49 PM
c/f
Default RE: AMT Pegasus SP spool up ???
Thanx Craig,
Now I'll have to check ECU serial numbers against each other to make sure they have not gotten swapped by myself mistakenly. and max setting on the KC standard peggy.......
The double wall is back from the bypass almost 3" but I do not have any exit holes so it will now based on your advice....
