RCU Forums - View Single Post - Draining Fuel after use....
Old 08-02-2005 | 06:11 AM
derekxec
Default RE: Draining Fuel after use....
i usually run the fuel out of the tank when im getting ready to put it up but if you dont want to then just pinch the line going to the carb till it dies then you will none in engine and the rest will be in tank..and dont forget to put after run oil in it when you are done for the day!
