RE: U-Can-Do 3d 46?
Hi. I have some problems whith the u- can do 60. The engine(Magnum 90 two stroke) is flooded. The tank is so much higher than the carb when mounted inverted. Is the 46 size the same way. I just cant the engine to work upside down. I tested it and mounted it upside just to see if there where any differences. Then it run just fine.
