RCU Forums - View Single Post - os 32 H engine
Old 08-02-2005 | 08:05 AM
BarracudaHockey's Avatar
BarracudaHockey
Default RE: os 32 H engine
Aluminum piston with a Brass piston liner thats Chrome plated.
ABN replace chrome with Nickel
No rings. When they run the metals expand at different rates. They also use a tapered piston sleeve that is tighter at the top. If you don't heat it sufficently to expand the top it puts strain on the rod and pin at the top of every stroke.
