RCU Forums - View Single Post - Why not ground the block?
Old 08-02-2005 | 09:44 AM
tkg
Default RE: Why not ground the block?
ORIGINAL: Advent
I was talking with a friend at the field the other day and it
got me thinking about how are gas engines ignitions are wired....
Can someone explain why the negative wire for the spark plug
is run directly to the plug instead of a simple ground wire screwed
to the block of the engine?
Thanks for your help.
Keep the ground lead short, use a ring terminal, tap the head...NO problem
The ground lead to the crankcase is long and may cause problems
