RCU Forums - View Single Post - Showtime
Thread: Showtime
Old 08-02-2005 | 10:31 AM
  #536
NeoGenesis's Avatar
NeoGenesis
My Feedback: (27)
Default RE: Showtime
This in addition to my earlier post....I should have put in more details. My ST weighs in at 8lbs 12 oz. My Saito 1.00 dosen't seem to be runnng at it's best....it's got some time on it. But....overall it will fly it good. Not Great. Cruise is at between 1/2 to to 3/4 throttle......verticle is ok....barely enough power to do good waterfalls. KE is no problem.....big loops no problem. Hover is done about 3/4 throttle....with very little pullout. I started to run a 16x4 instead of the 15x6....I'm turning right at 9200 RPM and it seems to pull better in the verticles. I'm also only running 15%.....30% may give it the extra kick it needs. There are many variables......I'm satisfied with the way it flies....but not thrilled. It all depends what you like to do. It would work for pattern...but all out 3D....it's pushing it.
Hope this helps!!
Neo Out!!!
