RE: REFLEX XTR REBOOTING COMPUTER
System Information
Time of this report: 7/31/2005, 18:09:05
Machine name: CYBER-QPPVZ6E4A
Operating System: Windows XP Professional (5.1, Build 2600) Service Pack 2 (2600.xpsp_sp2_gdr.050301-1519)
Language: English (Regional Setting: English)
System Manufacturer: VIA
System Model: 7VRX
BIOS: Version 1.00
Processor: AMD Athlon(tm) XP 2200+, MMX, 3DNow, ~1.8GHz
Memory: 1536MB RAM
Page File: 253MB used, 3181MB available
Windows Dir: C:\WINDOWS
DirectX Version: DirectX 9.0c (4.09.0000.0904)
DX Setup Parameters: Not found
DxDiag Version: 5.03.2600.2180 32bit Unicode
DxDiag Notes
DirectX Files Tab: No problems found.
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Sound Tab 2: No problems found.
Music Tab: No problems found.
Input Tab: No problems found.
Network Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (n/a)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (n/a)
DirectMusic: 0/5 (n/a)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: RADEON 9800 PRO
Manufacturer: ATI Technologies Inc.
Chip type: RADEON 9800 PRO AGP (0x4E48)
DAC type: Internal DAC(400MHz)
Device Key: Enum\PCI\VEN_1002&DEV_4E48&SUBSYS_00021002&REV_00
Display Memory: 128.0 MB
Current Mode: 1024 x 768 (32 bit) (60Hz)
Monitor: SyncMaster 730B(Analog)
Monitor Max Res: 1280,1024
Driver Name: ati2dvag.dll
Driver Version: 6.14.0010.6553 (English)
DDI Version: 9 (or higher)
Driver Attributes: Final Retail
Driver Date/Size: 6/28/2005 20:02:16, 232960 bytes
WHQL Logo'd: n/a
WHQL Date Stamp: n/a
VDD: n/a
Mini VDD: ati2mtag.sys
Mini VDD Date: 6/28/2005 20:01:56, 1241088 bytes
Device Identifier: {D7B71EE2-0D08-11CF-2B6A-0820A1C2CB35}
Vendor ID: 0x1002
Device ID: 0x4E48
SubSys ID: 0x00021002
Revision ID: 0x0000
Revision ID: 0x0000
Video Accel: ModeMPEG2_C ModeMPEG2_D ModeWMV8_B ModeWMV8_A ModeWMV9_B ModeWMV9_A
Deinterlace Caps: {6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{552C0DAD-CCBC-420B-83C8-74943CF9F1A6}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,2) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
Registry: OK
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
DDraw Test Result: Not run
D3D7 Test Result: Not run
D3D8 Test Result: Not run
D3D9 Test Result: Not run
Sound Devices
Description: SB Live! Wave Device
Default Sound Playback: Yes
Default Voice Playback: Yes
Hardware ID: PCI\VEN_1102&DEV_0002&SUBSYS_80641102&REV_07
Manufacturer ID: 1
Product ID: 100
Type: WDM
Driver Name: emu10k1m.sys
Driver Version: 5.12.0001.3300 (English)
WHQL Logo'd: n/a
Date and Size: 8/17/2001 05:19:26, 283904 bytes
Other Files:
Driver Provider: Microsoft
HW Accel Level: Full
Cap Flags: 0x0
Min/Max Sample Rate: 0, 0
Static/Strm HW Mix Bufs: 0, 0
Static/Strm HW 3D Bufs: 0, 0
HW Memory: 0
Voice Management: Yes
EAX(tm) 2.0 Listen/Src: Yes, Yes
I3DL2(tm) Listen/Src: No, No
Sensaura(tm) ZoomFX(tm): No
Registry: OK
Sound Test Result: Not run
Description: Modem #0 Line Playback (emulated)
Default Sound Playback: No
Default Voice Playback: No
Hardware ID:
Manufacturer ID: 1
Product ID: 81
Type: Emulated
Driver Name:
Driver Version:
Driver Attributes:
WHQL Logo'd:
Date and Size:
Other Files:
Driver Provider:
Cap Flags: 0x0
HW Memory: 0
Voice Management: No
EAX(tm) 2.0 Listen/Src: No, No
Registry: OK
Sound Capture Devices
Default Sound Capture: Yes
Default Voice Capture: Yes
Cap Flags: 0x0
Format Flags: 0x0
Description: Modem #0 Line Record (emulated)
Default Sound Capture: No
Default Voice Capture: No
Driver Name:
Driver Version:
Driver Attributes:
Date and Size:
Cap Flags: 0x0
Format Flags: 0x0
DirectMusic
DLS Path: C:\WINDOWS\SYSTEM32\drivers\GM.DLS
DLS Version: 1.00.0016.0002
Acceleration: n/a
Ports: Microsoft Synthesizer, Software (Not Kernel Mode), Output, DLS, Internal, Default Port
MPU-401, Hardware (Kernel Mode), Input, No DLS, External
MPU-401, Hardware (Kernel Mode), Output, No DLS, External
SB Live! MIDI UART, Hardware (Kernel Mode), Input, No DLS, External
SB Live! MIDI UART, Hardware (Kernel Mode), Output, No DLS, External
SB Live! Wave Device, Software (Kernel Mode), Output, DLS, Internal
Microsoft MIDI Mapper [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
B: SB Live! MIDI Synth [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
MPU-401 [Emulated], Hardware (Not Kernel Mode), Output, No DLS, External
A: SB Live! MIDI Synth [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
SB Live! MIDI UART [Emulated], Hardware (Not Kernel Mode), Output, No DLS, External
Microsoft GS Wavetable SW Synth [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
MPU-401 [Emulated], Hardware (Not Kernel Mode), Input, No DLS, External
SB Live! MIDI UART [Emulated], Hardware (Not Kernel Mode), Input, No DLS, External
Registry: OK
DirectInput Devices
Device Name: Mouse
Attached: 1
Controller ID: n/a
Vendor/Product ID: n/a
FF Driver: n/a
Device Name: Keyboard
Attached: 1
Controller ID: n/a
FF Driver: n/a
Device Name: ET-0405A-UV2.0-3
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x056A, 0x0011
FF Driver: n/a
Device Name: REFLEX RC USB Device
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x0B9B, 0x4012
FF Driver: n/a
Poll w/ Interrupt: No
Registry: OK
USB Devices
+ USB Root Hub
| Vendor/Product ID: 0x1106, 0x3038
| Matching Device ID: usb\root_hub
| Service: usbhub
| Driver: usbhub.sys, 8/3/2004 23:08:42, 57600 bytes
| Driver: usbd.sys, 8/29/2002 05:00:00, 4736 bytes
Gameport Devices
+ PCI bus
| Matching Device ID: *pnp0a03
| Service: pci
| Driver: pci.sys, 8/3/2004 23:07:46, 68224 bytes
+-+ Standard Game Port
| | Matching Device ID: *pnpb02f
| | Service: gameenum
| | Driver: gameenum.sys, 8/3/2004 23:08:21, 10624 bytes
+ PCI bus
| Service: pci
+-+ Creative SBLive! Gameport
| | Matching Device ID: pci\ven_1102&dev_7002
| | Lower Filters: ctljystk
| | Service: gameenum
| | Driver: ctljystk.sys, 8/17/2001 05:19:20, 3712 bytes
PS/2 Devices
+ Standard 101/102-Key or Microsoft Natural PS/2 Keyboard
| Matching Device ID: *pnp0303
| Service: i8042prt
| Driver: i8042prt.sys, 8/3/2004 23:14:36, 52736 bytes
| Driver: kbdclass.sys, 8/3/2004 22:58:32, 24576 bytes
+ Terminal Server Keyboard Driver
| Matching Device ID: root\rdp_kbd
| Upper Filters: kbdclass
| Service: TermDD
| Driver: termdd.sys, 8/4/2004 01:01:07, 40840 bytes
+ Microsoft USB Wheel Mouse Optical
| Vendor/Product ID: 0x045E, 0x0040
| Matching Device ID: hid\vid_045e&pid_0040
| Service: mouhid
| Driver: mouclass.sys, 8/3/2004 22:58:32, 23040 bytes
| Driver: mouhid.sys, 8/29/2002 05:00:00, 12160 bytes
+ HID-compliant mouse
| Matching Device ID: hid_device_system_mouse
| Service: mouhid
+ Terminal Server Mouse Driver
| Matching Device ID: root\rdp_mou
| Upper Filters: mouclass
| Service: TermDD
DirectPlay Service Providers
DirectPlay8 Modem Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
DirectPlay8 Serial Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
DirectPlay8 IPX Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
DirectPlay8 TCP/IP Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
Internet TCP/IP Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.2600.2180)
IPX Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.2600.2180)
Modem Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.2180)
Serial Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.2180)
DirectPlay Voice Wizard Tests: Full Duplex: Not run, Half Duplex: Not run, Mic: Not run
DirectPlay Test Result: Not run
Registry: OK
DirectPlay Adapters
DirectPlay8 Modem Service Provider: Intel(R) 536EP Modem
DirectPlay8 Serial Service Provider: COM1
DirectPlay8 Serial Service Provider: COM2
DirectPlay8 Serial Service Provider: COM3
DirectPlay8 TCP/IP Service Provider: Local Area Connection - IPv4 -
DirectPlay Voice Codecs
Voxware VR12 1.4kbit/s
Voxware SC06 6.4kbit/s
Voxware SC03 3.2kbit/s
MS-PCM 64 kbit/s
MS-ADPCM 32.8 kbit/s
Microsoft GSM 6.10 13 kbit/s
TrueSpeech(TM) 8.6 kbit/s
DirectPlay Lobbyable Apps
Disk & DVD/CD-ROM Drives
Drive: C:
Free Space: 24.0 GB
Total Space: 38.2 GB
File System: NTFS
Model: MAXTOR 6L040J2
Drive: I:
Model: LG DVD-ROM DRD8160B
Driver: c:\windows\system32\drivers\cdrom.sys, 5.01.2600.2180 (English), 8/3/2004 22:59:52, 49536 bytes
Drive: J:
Model: PLEXTOR CD-R PX-W4012A
System Devices
Name: Intel(R) 536EP Modem
Device ID: PCI\VEN_8086&DEV_1040&SUBSYS_10008086&REV_00\3&61A AA01&0&60
Driver: n/a
Name: VIA CPU to AGP Controller
Device ID: PCI\VEN_1106&DEV_B099&SUBSYS_00000000&REV_00\3&61A AA01&0&08
Driver: C:\WINDOWS\system32\DRIVERS\VIAAGP.SYS, 5.01.2600.2180 (English), 8/3/2004 23:07:42, 42240 bytes
Name: PCI standard ISA bridge
Device ID: PCI\VEN_1106&DEV_3147&SUBSYS_00000000&REV_00\3&61A AA01&0&88
Driver: C:\WINDOWS\system32\DRIVERS\isapnp.sys, 5.01.2600.0000 (English), 8/29/2002 05:00:00, 35840 bytes
Name: VIA USB Enhanced Host Controller
Device ID: PCI\VEN_1106&DEV_3104&SUBSYS_12340925&REV_51\3&61A AA01&0&A2
Driver: C:\WINDOWS\system32\drivers\usbehci.sys, 5.01.2600.2180 (English), 8/3/2004 23:08:37, 26624 bytes
Driver: C:\WINDOWS\system32\drivers\usbport.sys, 5.01.2600.2180 (English), 8/3/2004 23:08:42, 142976 bytes
Driver: C:\WINDOWS\system32\usbui.dll, 5.01.2600.2180 (English), 8/4/2004 00:56:46, 74240 bytes
Driver: C:\WINDOWS\system32\drivers\usbhub.sys, 5.01.2600.2180 (English), 8/3/2004 23:08:42, 57600 bytes
Driver: C:\WINDOWS\system32\hccoin.dll, 5.01.2600.2180 (English), 8/4/2004 00:56:42, 7168 bytes
Name: VIA Tech CPU to PCI Bridge
Device ID: PCI\VEN_1106&DEV_3099&SUBSYS_00000000&REV_00\3&61A AA01&0&00
Driver: n/a
Name: VIA OHCI Compliant IEEE 1394 Host Controller
Device ID: PCI\VEN_1106&DEV_3044&SUBSYS_30441106&REV_46\3&61A AA01&0&68
Driver: C:\WINDOWS\system32\DRIVERS\ohci1394.sys, 5.01.2600.2180 (English), 8/3/2004 23:10:08, 61056 bytes
Driver: C:\WINDOWS\system32\DRIVERS\1394bus.sys, 5.01.2600.2180 (English), 8/3/2004 23:10:06, 53248 bytes
Driver: C:\WINDOWS\system32\DRIVERS\nic1394.sys, 5.01.2600.2180 (English), 8/3/2004 22:58:29, 61824 bytes
Driver: C:\WINDOWS\system32\DRIVERS\arp1394.sys, 5.01.2600.2180 (English), 8/3/2004 22:58:29, 60800 bytes
Driver: C:\WINDOWS\system32\DRIVERS\enum1394.sys, 5.01.2600.0000 (English), 8/17/2001 06:46:40, 6400 bytes
Name: VIA Rev 5 or later USB Universal Host Companion Controller
Device ID: PCI\VEN_1106&DEV_3038&SUBSYS_12340925&REV_50\3&61A AA01&0&A1
Driver: C:\WINDOWS\system32\drivers\usbuhci.sys, 5.01.2600.2180 (English), 8/3/2004 23:08:37, 20480 bytes
Device ID: PCI\VEN_1106&DEV_3038&SUBSYS_12340925&REV_50\3&61A AA01&0&A0
Name: VIA Rev 5 or later USB Universal Host Controller
Device ID: PCI\VEN_1106&DEV_3038&SUBSYS_12340925&REV_23\3&61A AA01&0&8B
Device ID: PCI\VEN_1106&DEV_3038&SUBSYS_12340925&REV_23\3&61A AA01&0&8A
Name: VIA Bus Master IDE Controller
Device ID: PCI\VEN_1106&DEV_0571&SUBSYS_05711106&REV_06\3&61A AA01&0&89
Driver: C:\WINDOWS\system32\DRIVERS\viaide.sys, 1.00.0001.0001 (English), 8/3/2004 22:59:42, 5376 bytes
Driver: C:\WINDOWS\system32\DRIVERS\pciidex.sys, 5.01.2600.2180 (English), 8/3/2004 22:59:41, 25088 bytes
Driver: C:\WINDOWS\system32\DRIVERS\atapi.sys, 5.01.2600.2180 (English), 8/3/2004 22:59:42, 95360 bytes
Name: Creative SBLive! Gameport
Device ID: PCI\VEN_1102&DEV_7002&SUBSYS_00201102&REV_07\3&61A AA01&0&59
Driver: C:\WINDOWS\system32\DRIVERS\gameenum.sys, 5.01.2600.2180 (English), 8/3/2004 23:08:21, 10624 bytes
Driver: C:\WINDOWS\system32\drivers\ctljystk.sys, 5.01.2501.0000 (English), 8/17/2001 05:19:20, 3712 bytes
Name: Creative SB Live! Series (WDM)
Device ID: PCI\VEN_1102&DEV_0002&SUBSYS_80641102&REV_07\3&61A AA01&0&58
Driver: n/a
Name: Realtek RTL8139 Family PCI Fast Ethernet NIC
Device ID: PCI\VEN_10EC&DEV_8139&SUBSYS_813910EC&REV_10\3&61A AA01&0&50
Driver: C:\WINDOWS\system32\DRIVERS\RTL8139.sys, 5.398.0613.2003 (English), 8/3/2004 22:31:32, 20992 bytes
Name: RADEON 9800 PRO - Secondary
Device ID: PCI\VEN_1002&DEV_4E68&SUBSYS_00031002&REV_00\4&618 BA55&0&0108
Driver: C:\WINDOWS\system32\DRIVERS\ati2mtag.sys, 6.14.0010.6553 (English), 6/28/2005 20:01:56, 1241088 bytes
Driver: C:\WINDOWS\system32\DRIVERS\ati2erec.dll, 1.00.0000.0005 (English), 6/28/2005 19:03:13, 40960 bytes
Driver: C:\WINDOWS\system32\DRIVERS\ativvpxx.vp, 6/28/2005 23:15:58, 21472 bytes
Driver: C:\WINDOWS\system32\DRIVERS\ativckxx.vp, 3/10/2005 07:52:42, 58521 bytes
Driver: C:\WINDOWS\system32\DRIVERS\ativcaxx.vp, 4/7/2005 08:20:56, 900 bytes
Driver: C:\WINDOWS\system32\DRIVERS\ativcaxx.cpa, 4/7/2005 08:20:56, 524850 bytes
Driver: C:\WINDOWS\system32\ati2dvag.dll, 6.14.0010.6553 (English), 6/28/2005 20:02:16, 232960 bytes
Driver: C:\WINDOWS\system32\ati2cqag.dll, 6.14.0010.0289 (English), 6/28/2005 18:57:38, 208896 bytes
Driver: C:\WINDOWS\system32\Ati2mdxx.exe, 6.14.0010.2494 (English), 6/28/2005 19:57:05, 25088 bytes
Driver: C:\WINDOWS\system32\ati3duag.dll, 6.14.0010.0327 (English), 6/28/2005 19:47:51, 2360736 bytes
Driver: C:\WINDOWS\system32\ativvaxx.dll, 6.14.0001.0061 (English), 6/28/2005 19:41:41, 648000 bytes
Driver: C:\WINDOWS\system32\atiicdxx.dat, 6/10/2005 13:59:16, 95617 bytes
Driver: C:\WINDOWS\system32\ATIDDC.DLL, 6.14.0010.0006 (English), 6/28/2005 19:55:07, 53248 bytes
Driver: C:\WINDOWS\system32\atitvo32.dll, 6.14.0010.4200 (English), 6/28/2005 19:03:00, 17408 bytes
Driver: C:\WINDOWS\system32\ativcoxx.dll, 6.13.0010.0005 (English), 11/9/2001 08:01:04, 24064 bytes
Driver: C:\WINDOWS\system32\ati2evxx.exe, 6.14.0010.4117 (English), 6/28/2005 19:55:38, 376832 bytes
Driver: C:\WINDOWS\system32\ati2evxx.dll, 6.14.0010.4117 (English), 6/28/2005 19:56:48, 46080 bytes
Driver: C:\WINDOWS\system32\atipdlxx.dll, 6.14.0010.2493 (English), 6/28/2005 19:57:25, 94208 bytes
Driver: C:\WINDOWS\system32\Oemdspif.dll, 6.14.0001.0013 (English), 6/28/2005 19:57:13, 73728 bytes
Driver: C:\WINDOWS\system32\ati2edxx.dll, 6.14.0010.2497 (English), 6/28/2005 19:56:58, 39936 bytes
Driver: C:\WINDOWS\system32\atikvmag.dll, 6.14.0010.0024 (English), 6/28/2005 19:30:09, 143360 bytes
Driver: C:\WINDOWS\system32\ATIDEMGR.dll, 1.02.2006.0273 (English), 6/28/2005 22:09:08, 241664 bytes
Driver: C:\WINDOWS\system32\atifglpf.xml, 5/9/2005 17:47:29, 5396 bytes
Driver: C:\WINDOWS\system32\atioglxx.dll, 6.14.0010.5220 (English), 6/28/2005 20:18:35, 4857856 bytes
Driver: C:\WINDOWS\system32\atioglx1.dll, 6.14.0010.1011 (English), 6/28/2005 21:26:40, 6684672 bytes
Driver: C:\WINDOWS\system32\atiiiexx.dll, 6.14.0010.4004 (English), 6/28/2005 22:41:46, 307200 bytes
Device ID: PCI\VEN_1002&DEV_4E48&SUBSYS_00021002&REV_00\4&618 BA55&0&0008
DirectX Components
ddraw.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:42 266240 bytes
ddrawex.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:42 27136 bytes
dxapi.sys: 5.01.2600.0000 English Final Retail 8/29/2002 05:00:00 10496 bytes
d3d8.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:41 1179648 bytes
d3d8thk.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:41 8192 bytes
d3d9.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:41 1689088 bytes
d3dim.dll: 5.01.2600.0000 English Final Retail 8/29/2002 05:00:00 436224 bytes
d3dim700.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:41 825344 bytes
d3dramp.dll: 5.01.2600.0000 English Final Retail 8/29/2002 05:00:00 590336 bytes
d3drm.dll: 5.01.2600.0000 English Final Retail 8/29/2002 05:00:00 350208 bytes
d3dxof.dll: 5.01.2600.0000 English Final Retail 8/29/2002 05:00:00 47616 bytes
d3dpmesh.dll: 5.01.2600.0000 English Final Retail 8/29/2002 05:00:00 34816 bytes
dplay.dll: 5.00.2134.0001 English Final Retail 8/29/2002 05:00:00 33040 bytes
dplayx.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:42 229888 bytes
dpmodemx.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:42 23552 bytes
dpwsock.dll: 5.00.2134.0001 English Final Retail 8/29/2002 05:00:00 42768 bytes
dpwsockx.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:42 57344 bytes
dplaysvr.exe: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:48 30208 bytes
dpnsvr.exe: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:48 18432 bytes
dpnet.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:42 375296 bytes
dpnlobby.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:03 3584 bytes
dpnaddr.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:03 3584 bytes
dpvoice.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:42 212480 bytes
dpvsetup.exe: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:48 83456 bytes
dpvvox.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:42 116736 bytes
dpvacm.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:42 21504 bytes
dpnhpast.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:42 35328 bytes
dpnhupnp.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:42 60928 bytes
dpserial.dll: 5.00.2134.0001 English Final Retail 8/29/2002 05:00:00 53520 bytes
dinput.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:42 159232 bytes
dinput8.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:42 181760 bytes
dimap.dll: 5.01.2600.0000 English Final Retail 8/29/2002 05:00:00 44032 bytes
diactfrm.dll: 5.01.2600.0000 English Final Retail 8/29/2002 05:00:00 394240 bytes
joy.cpl: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:57 68608 bytes
gcdef.dll: 5.01.2600.0000 English Final Retail 8/29/2002 05:00:00 76800 bytes
pid.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 35328 bytes
gameenum.sys: 5.01.2600.2180 English Final Retail 8/3/2004 23:08:21 10624 bytes
dsound.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:42 367616 bytes
dsound3d.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:42 1294336 bytes
dswave.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:42 19456 bytes
dsdmo.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:42 181760 bytes
dsdmoprp.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:42 71680 bytes
dmusic.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:42 104448 bytes
dmband.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:42 28672 bytes
dmcompos.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:42 61440 bytes
dmime.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:42 181248 bytes
dmloader.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:42 35840 bytes
dmstyle.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:42 105984 bytes
dmsynth.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:42 103424 bytes
dmscript.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:42 82432 bytes
dx7vb.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:42 619008 bytes
dx8vb.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:42 1227264 bytes
dxdiagn.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:42 2113536 bytes
mfc40.dll: 4.01.0000.6140 English Final Retail 8/29/2002 05:00:00 924432 bytes
mfc42.dll: 6.02.4131.0000 English Final Retail 8/4/2004 00:56:42 1028096 bytes
wsock32.dll: 5.01.2600.2180 English Final Retail 8/4/2004 00:56:46 22528 bytes
amstream.dll: 6.05.2600.2180 English Final Retail 8/4/2004 00:56:41 70656 bytes
devenum.dll: 6.05.2600.2180 English Final Retail 8/4/2004 00:56:42 59904 bytes
dxmasf.dll: 6.04.0009.1125 English Final Retail 8/4/2004 00:56:42 498205 bytes
mciqtz32.dll: 6.05.2600.2180 English Final Retail 8/4/2004 00:56:42 35328 bytes
mpg2splt.ax: 6.05.2600.2180 English Final Retail 8/4/2004 00:56:57 148992 bytes
msdmo.dll: 6.05.2600.2180 English Final Retail 8/4/2004 00:56:43 14336 bytes
encapi.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:42 20480 bytes
qasf.dll: 9.00.0000.3250 English Final Retail 8/4/2004 00:56:44 237568 bytes
qcap.dll: 6.05.2600.2180 English Final Retail 8/4/2004 00:56:44 192512 bytes
qdv.dll: 6.05.2600.2180 English Final Retail 8/4/2004 00:56:44 279040 bytes
qdvd.dll: 6.05.2600.2180 English Final Retail 8/4/2004 00:56:44 385024 bytes
qedit.dll: 6.05.2600.2180 English Final Retail 8/4/2004 00:56:44 562176 bytes
qedwipes.dll: 6.05.2600.2180 English Final Retail 8/4/2004 00:56:24 733696 bytes
quartz.dll: 6.05.2600.2180 English Final Retail 8/4/2004 00:56:44 1287680 bytes
strmdll.dll: 4.01.0000.3928 English Final Retail 8/4/2004 00:56:45 246302 bytes
iac25_32.ax: 2.00.0005.0053 English Final Retail 8/4/2004 00:56:57 199680 bytes
ir41_32.ax: 4.51.0016.0003 English Final Retail 8/4/2004 00:56:57 848384 bytes
ir41_qc.dll: 4.30.0062.0002 English Final Retail 8/4/2004 00:56:42 120320 bytes
ir41_qcx.dll: 4.30.0064.0001 English Final Retail 8/4/2004 00:56:42 338432 bytes
ir50_32.dll: 5.2562.0015.0055 English Final Retail 8/4/2004 00:56:42 755200 bytes
ir50_qc.dll: 5.00.0063.0048 English Final Retail 8/4/2004 00:56:42 200192 bytes
ir50_qcx.dll: 5.00.0064.0048 English Final Retail 8/4/2004 00:56:42 183808 bytes
ivfsrc.ax: 5.10.0002.0051 English Final Retail 8/4/2004 00:56:57 154624 bytes
mswebdvd.dll: 6.05.2600.2180 English Final Retail 8/4/2004 00:56:44 204288 bytes
ks.sys: 5.03.2600.2180 English Final Retail 8/3/2004 23:15:21 140928 bytes
ksproxy.ax: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:57 130048 bytes
ksuser.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:42 4096 bytes
stream.sys: 5.03.2600.2180 English Final Retail 8/3/2004 23:08:02 48640 bytes
mspclock.sys: 5.03.2600.2180 English Final Retail 8/3/2004 22:58:38 5376 bytes
mspqm.sys: 5.01.2600.2180 English Final Retail 8/3/2004 22:58:40 4992 bytes
mskssrv.sys: 5.03.2600.2180 English Final Retail 8/3/2004 22:58:41 7552 bytes
swenum.sys: 5.03.2600.2180 English Final Retail 8/3/2004 22:58:41 4352 bytes
mpeg2data.ax: 6.05.2600.2180 English Final Retail 8/4/2004 00:56:57 118272 bytes
msvidctl.dll: 6.05.2600.2180 English Final Retail 8/4/2004 00:56:43 1428480 bytes
vbisurf.ax: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:57 30720 bytes
msyuv.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 17408 bytes
wstdecod.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:46 50688 bytes
DirectShow Filters
DirectShow Filters:
WMAudio Decoder DMO,0x00800800,1,1,,
WMSpeech Decoder DMO,0x00600800,1,1,,
Mpeg4s Decoder DMO,0x00800001,1,1,,
WMV Screen decoder DMO,0x00800001,1,1,,
WMVideo Decoder DMO,0x00800001,1,1,,
DMO JPEG Video Decompressor,0x00000000,1,1,,
Mpeg43 Decoder DMO,0x00800001,1,1,,
Mpeg4 Decoder DMO,0x00800001,1,1,,
WMT MuxDeMux Filter,0x00200000,0,0,wmm2filt.dll,2.01.4026.0000
Full Screen Renderer,0x00200000,1,0,quartz.dll,6.05.2600.2180
VW AudioConvert,0x00200000,1,1,audconv.ax,2.00.0696.0 000
Roxio Quicktime Parser ,0x00800000,0,2,RXQuicktime.ax,1.00.0000.0000
VW AlphaSplitter,0x00200000,1,1,AlphaSplitter.ax,2.00 .0696.0000
VW VideoCutList,0x00200000,1,1,vCutList.ax,2.00.0696. 0000
DvdDump,0x00200000,1,0,dvddump.ax,1.01.0001.0007
DV Muxer,0x00400000,0,0,qdv.dll,6.05.2600.2180
Color Space Converter,0x00400001,1,1,quartz.dll,6.05.2600.2180
MGI CrossGraph Renderer,0x00200000,1,0,MGICGFilter.ax,2.00.0696.0 000
WM ASF Reader,0x00400000,0,0,qasf.dll,9.00.0000.3250
AVI Splitter,0x00600000,1,1,quartz.dll,6.05.2600.2180
WMT AudioAnalyzer,0x00200000,1,1,wmm2filt.dll,2.01.402 6.0000
VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,6.05.2600.2180
VW Pan Zoom Filter,0x00200000,1,1,PanZoom.ax,2.00.0696.0000
Windows Media Audio Decoder,0x00800001,1,1,msadds32.ax,8.00.0000.4487
AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,6.05.2600.2180
Roxio MPEG Splitter,0x00200000,1,2,RxMpegX.ax,2.00.0233.0000
ROXIO VCD/SVCD Navigator,0x00200000,0,0,Navigator.dll,2.00.0233.0 000
WMT Format Conversion,0x00200000,1,1,wmm2filt.dll,2.01.4026.0 000
StreamBufferSink,0x00200000,0,0,sbe.dll,6.05.2600. 2180
WMT Black Frame Generator,0x00200000,1,1,wmm2filt.dll,2.01.4026.00 00
VW ThumbnailGrabber,0x00200000,1,0,thumbnailgraber.ax ,2.00.0696.0000
MJPEG Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.2 180
ROXIO Subpicture Decoder,0x00200000,1,1,SubPictDec.dll,2.00.0233.00 00
WMT Screen Capture filter,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
Microsoft Screen Video Decompressor,0x00800000,1,1,msscds32.ax,8.00.0000. 4487
MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,6.05.2600.2180
SAMI (CC) Parser,0x00400000,1,1,quartz.dll,6.05.2600.2180
VW SpyPos,0x00200000,1,1,MGINullIP.ax,2.00.0696.0000
MPEG Layer-3 Decoder,0x00810000,1,1,l3codecx.ax,1.05.0000.0050
MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,6.05.2600.2180
ROXIO WAV Dest,0x00200000,0,0,WavHead.ax,2.00.0696.0000
ACELP.net Sipro Lab Audio Decoder,0x00800001,1,1,acelpdec.ax,1.04.0000.0000
Internal Script Command Renderer,0x00800001,1,0,quartz.dll,6.05.2600.2180
ROXIO MPEG Partition Filter,0x00600000,1,1,PartitionFilter.dll,2.00.024 3.0000
MPEG Audio Decoder,0x03680001,1,1,quartz.dll,6.05.2600.2180
VW Looper,0x00200000,1,1,Looper.ax,2.00.0696.0000
File Source (Netshow URL),0x00400000,0,1,wmpasf.dll,9.00.0000.3250
Roxio MPEG2 Muxer,0x00200000,2,1,RoxioMPEGMuxer.dll,2.00.0243. 0000
WMT Import Filter,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
DV Splitter,0x00600000,1,2,qdv.dll,6.05.2600.2180
Bitmap Generate,0x00200000,1,1,wmm2filt.dll,2.01.4026.000 0
ROXIO SubPicture Encoder,0x00200000,1,1,SubPictEnc.dll,2.00.0243.00 00
Windows Media Video Decoder,0x00800000,1,1,wmvds32.ax,8.00.0000.4487
Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,
Windows Media Video Decoder,0x00800000,1,1,wmv8ds32.ax,8.00.0000.4000
WMT VIH2 Fix,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Record Queue,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
VW MediaPlacer,0x00200000,2,2,MediaPlacer.ax,2.00.069 6.0000
VW vlooper,0x00200000,1,1,vlooper.ax,2.00.0696.0000
VW De-Interlace Filter,0x00200000,1,1,DeInter.ax,2.00.0696.0000
Windows Media Multiplexer,0x00600000,1,1,wmpasf.dll,9.00.0000.32 50
ASX file Parser,0x00600000,1,1,wmpasf.dll,9.00.0000.3250
ASX v.2 file Parser,0x00600000,1,0,wmpasf.dll,9.00.0000.3250
NSC file Parser,0x00600000,1,1,wmpasf.dll,9.00.0000.3250
Roxio MPEG2 Video Encoder,0x00200000,1,1,RoxioVideoMPEG.dll,2.00.024 3.0000
ACM Wrapper,0x00600000,1,1,quartz.dll,6.05.2600.2180
Windows Media source filter,0x00600000,0,2,wmpasf.dll,9.00.0000.3250
Video Renderer,0x00800001,1,0,quartz.dll,6.05.2600.2180
VW ColorSpace Converter,0x00200000,1,1,ColorSpConv.dll,2.00.0696 .0000
Frame Eater,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,6.05.2600.2180
Line 21 Decoder,0x00600000,1,1,qdvd.dll,6.05.2600.2180
Video Port Manager,0x00600000,2,1,quartz.dll,6.05.2600.2180
WST Decoder,0x00600000,1,1,wstdecod.dll,5.03.2600.2180
Video Renderer,0x00400000,1,0,quartz.dll,6.05.2600.2180
VW Input Selector New,0x00200000,1,0,InputSelector.ax,2.00.0696.0000
VW Audio Source,0x00200000,0,1,AudioSrc.ax,2.00.0696.0000
WM ASF Writer,0x00400000,0,0,qasf.dll,9.00.0000.3250
WMT Sample Information Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
ROXIO MPEG Writer,0x00200000,1,0,MGIRawWriter.dll,2.00.0243.0 000
VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,5.03.2600.2180
Microsoft MPEG-4 Video Decompressor,0x00800000,1,1,mpg4ds32.ax,8.00.0000. 4487
File writer,0x00200000,1,0,qcap.dll,6.05.2600.2180
Roxio Audio Decoder (DVD),0x00600000,1,1,RoxioDVDAudio.dll,2.00.0243.0 000
Roxio DVD MPEG2 Decoder,0x00200000,1,1,RoxioDVDDecoder.dll,2.00.02 33.0000
MGI Scene Detector,0x00200000,1,1,SceneDetector.ax,2.00.0696 .0000
VW Latency,0x00200000,1,1,latency.ax,2.00.0696.0000
MGI CrossGraph Source,0x00200000,0,1,MGICGFilter.ax,2.00.0696.000 0
WMT Log Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WMT Virtual Renderer,0x00200000,1,0,wmm2filt.dll,2.01.4026.000 0
Photo Story Source Filter,0x00200000,0,1,DIPS10PSSourceFilter.dll,1.0 2.0000.1416
DVD Navigator,0x00200000,0,2,qdvd.dll,6.05.2600.2180
Overlay Mixer2,0x00400000,1,1,qdvd.dll,6.05.2600.2180
VW AudioMixFlt,0x00200000,1,1,audmf.ax,2.00.0696.0000
VW AudioGrabber,0x00200000,1,0,thumbnailgraber.ax,2.0 0.0696.0000
VW QuickGrabber,0x00200000,1,0,thumbnailgraber.ax,2.0 0.0696.0000
Roxio SVCD MPEG2 Decoder,0x00200000,1,1,RoxioDVDDecoder.dll,2.00.02 33.0000
AVI Draw,0x00600064,9,1,quartz.dll,6.05.2600.2180
.RAM file Parser,0x00600000,1,0,wmpasf.dll,9.00.0000.3250
VW Video Resampler Filter,0x00200000,1,1,VResamFilt.ax,2.00.0696.0000
WMT DirectX Transform Wrapper,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
G.711 Codec,0x00200000,1,1,g711codc.ax,5.01.2600.0000
MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,6.05.2600 .2180
Sewer,0x00200000,1,0,MVWcDSutil.dll,2.00.0696.0000
DV Video Decoder,0x00800000,1,1,qdv.dll,6.05.2600.2180
Roxio MPEG1 Muxer,0x00200000,2,1,RoxioMPEGMuxer.dll,2.00.0243. 0000
Windows Media Update Filter,0x00400000,1,0,wmpasf.dll,9.00.0000.3250
VW Input Selector,0x00200000,1,0,InputSelector.ax,2.00.0696 .0000
ASF DIB Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.3250
ASF ACM Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.3250
ASF ICM Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.3250
ASF URL Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.3250
ASF JPEG Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.3250
ASF DJPEG Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.3250
ASF embedded stuff Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.3250
VW VideoInfo Transcoder,0x00200000,1,1,VWVinfoXcoder.ax,2.00.06 96.0000
MGI DV Scene Change Detector Tee,0x00200000,1,1,DVSceneCDTee.ax,2.00.0696.0000
9x8Resize,0x00200000,1,1,wmm2filt.dll,2.01.4026.00 00
WIA Stream Snapshot Filter,0x00200000,1,1,wiasf.ax,1.00.0000.0000
Audio Chunker,0x00200000,1,1,Chunker.ax,2.00.0696.0000
WAV Dest,0x00200000,0,0,DIPS10WavDest.dll,1.02.0000.14 16
Allocator Fix,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
SampleGrabber,0x00200000,1,1,qedit.dll,6.05.2600.2 180
Null Renderer,0x00200000,1,0,qedit.dll,6.05.2600.2180
Roxio MPEG2 Video Decoder,0x00640000,1,1,RoxioVideoMPEG.dll,2.00.024 3.0000
WMT Virtual Source,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
MPEG-2 Sections and Tables,0x005fffff,1,0,mpeg2data.ax,
WMT Interlacer,0x00200000,1,1,wmm2filt.dll,2.01.4026.0 000
Raw Reader (Async.),0x00200000,0,1,MultiFileReader.ax,1.01.00 00.0013
StreamBufferSource,0x00200000,0,0,sbe.dll,6.05.260 0.2180
Smart Tee,0x00200000,1,2,qcap.dll,6.05.2600.2180
Overlay Mixer,0x00200000,0,0,qdvd.dll,6.05.2600.2180
AVI Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.2 180
Uncompressed Domain Shot Detection Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Roxio Dump Filter,0x00200000,1,0,RxDump.ax,1.01.0001.0007
Roxio Video Transition Filter,0x00200000,1,0,VideoTransition.ax,1.01.0001 .0007
Roxio MPEG1 Video Encoder,0x00200000,1,1,RoxioVideoMPEG.dll,2.00.024 3.0000
AVI/WAV File Source,0x00400000,0,2,quartz.dll,6.05.2600.2180
QuickTime Movie Parser,0x00600000,1,1,quartz.dll,6.05.2600.2180
Wave Parser,0x00400000,1,1,quartz.dll,6.05.2600.2180
MIDI Parser,0x00400000,1,1,quartz.dll,6.05.2600.2180
Multi-file Parser,0x00400000,1,1,quartz.dll,6.05.2600.2180
Lyric Parser,0x00400000,1,1,quartz.dll,6.05.2600.2180
File stream renderer,0x00400000,1,1,quartz.dll,6.05.2600.2180
XML Playlist,0x00400000,1,0,wmpasf.dll,9.00.0000.3250
Video Effects,0x00200000,1,1,vergb24.ax,1.01.0001.0007
Roxio DV Frame Detector,0x00200000,1,1,dvframedet.ax,1.01.0326.00 00
Roxio MPEG2 Demuxer,0x00800000,1,2,RoxioMPEGDemuxer.dll,2.00.0 243.0000
AVI Mux,0x00200000,1,0,qcap.dll,6.05.2600.2180
Line 21 Decoder 2,0x00600002,1,1,quartz.dll,6.05.2600.2180
File Source (Async.),0x00400000,0,1,quartz.dll,6.05.2600.2180
File Source (URL),0x00400000,0,1,quartz.dll,6.05.2600.2180
WMT DV Extract,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Roxio MPEG1 Audio Encoder ,0x00200000,1,1,RoxioAudioEnc.dll,2.00.0243.0000
Multi File Reader (Async.),0x00400000,0,1,MultiFileReader.ax,1.01.00 00.0013
WMT Switch Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WMT Volume,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
VW Switch,0x00200000,1,1,MGISwitch.ax,2.00.0696.0000
Stretch Video,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Windows Media Pad VU Data Grabber,0x00600000,1,0,wmmfilt.dll,1.01.2427.0001
Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,6.05.2600.2180
QT Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.2 180
ShotBoundaryDet,0x00200000,1,1,wmmfilt.dll,1.01.24 27.0001
MPEG Video Decoder,0x40000001,1,1,quartz.dll,6.05.2600.2180
WDM Streaming Data Transforms:
Microsoft Kernel Acoustic Echo Canceller,0x00200000,2,2,,5.03.2600.2180
Microsoft Kernel GS Wavetable Synthesizer,0x00200000,1,1,,5.03.2600.2180
Microsoft Kernel DLS Synthesizer,0x00200000,1,1,,5.03.2600.2180
Microsoft Kernel DRM Audio Descrambler,0x00200000,1,1,,5.03.2600.2180
Video Compressors:
DMO JPEG Video Compressor,0x00000000,1,1,,
WMVideo Encoder DMO,0x00600800,1,1,,
MSScreen encoder DMO,0x00600800,1,1,,
WMVideo9 Encoder DMO,0x00600800,1,1,,
MSScreen 9 encoder DMO,0x00600800,1,1,,
DV Video Encoder,0x00200000,0,0,qdv.dll,6.05.2600.2180
MJPEG Compressor,0x00200000,0,0,quartz.dll,6.05.2600.218 0
Cinepak Codec by Radius,0x00200000,1,1,qcap.dll,6.05.2600.2180
Intel 4:2:0 Video V2.50,0x00200000,1,1,qcap.dll,6.05.2600.2180
Intel Indeo(R) Video R3.2,0x00200000,1,1,qcap.dll,6.05.2600.2180
Intel IYUV codec,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft H.261 Video Codec,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft H.263 Video Codec,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft RLE,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft Video 1,0x00200000,1,1,qcap.dll,6.05.2600.2180
Audio Compressors:
WM Speech Encoder DMO,0x00600800,1,1,,
WMAudio Encoder DMO,0x00600800,1,1,,
IMA ADPCM,0x00200000,1,1,quartz.dll,6.05.2600.2180
Microsoft ADPCM,0x00200000,1,1,quartz.dll,6.05.2600.2180
ACELP.net,0x00200000,1,1,quartz.dll,6.05.2600.2180
DSP Group TrueSpeech(TM),0x00200000,1,1,quartz.dll,6.05.2600 .2180
Windows Media Audio V1,0x00200000,1,1,quartz.dll,6.05.2600.2180
Windows Media Audio V2,0x00200000,1,1,quartz.dll,6.05.2600.2180
GSM 6.10,0x00200000,1,1,quartz.dll,6.05.2600.2180
Microsoft G.723.1,0x00200000,1,1,quartz.dll,6.05.2600.2180
CCITT A-Law,0x00200000,1,1,quartz.dll,6.05.2600.2180
CCITT u-Law,0x00200000,1,1,quartz.dll,6.05.2600.2180
MPEG Layer-3,0x00200000,1,1,quartz.dll,6.05.2600.2180
Audio Capture Sources:
SB Live! Wave Device,0x00200000,0,0,qcap.dll,6.05.2600.2180
Modem #0 Line Record,0x00200000,0,0,qcap.dll,6.05.2600.2180
Midi Renderers:
A: SB Live! MIDI Synth,0x00200000,1,0,quartz.dll,6.05.2600.2180
B: SB Live! MIDI Synth,0x00200000,1,0,quartz.dll,6.05.2600.2180
Default MidiOut Device,0x00800000,1,0,quartz.dll,6.05.2600.2180
Microsoft GS Wavetable SW Synth,0x00200000,1,0,quartz.dll,6.05.2600.2180
MPU-401,0x00200000,1,0,quartz.dll,6.05.2600.2180
SB Live! MIDI UART,0x00200000,1,0,quartz.dll,6.05.2600.2180
WDM Streaming Capture Devices:
,0x00000000,0,0,,
,0x00000000,0,0,,
,0x00000000,0,0,,
SB Live! MIDI UART,0x00200000,3,2,,5.03.2600.2180
SB Live! Wave Device,0x00200000,3,2,,5.03.2600.2180
WDM Streaming Rendering Devices:
,0x00000000,0,0,,
A: SB Live! MIDI Synth,0x00200000,1,1,,5.03.2600.2180
B: SB Live! MIDI Synth,0x00200000,1,1,,5.03.2600.2180
BDA Transport Information Renderers:
MPEG-2 Sections and Tables,0x00600000,1,0,mpeg2data.ax,
WDM Streaming Mixer Devices:
Microsoft Kernel Wave Audio Mixer,0x00000000,0,0,,
BDA CP/CA Filters:
Decrypt/Tag,0x00600000,1,0,encdec.dll,6.05.2600.2180
Encrypt/Tag,0x00200000,0,0,encdec.dll,6.05.2600.2180
XDS Codec,0x00200000,0,0,encdec.dll,6.05.2600.2180
Audio Renderers:
SB Live! Wave Device,0x00200000,1,0,quartz.dll,6.05.2600.2180
Default DirectSound Device,0x00800000,1,0,quartz.dll,6.05.2600.2180
Default WaveOut Device,0x00200000,1,0,quartz.dll,6.05.2600.2180
DirectSound: Modem #0 Line Playback (emulated),0x00200000,1,0,quartz.dll,6.05.2600.218 0
DirectSound: SB Live! Wave Device,0x00200000,1,0,quartz.dll,6.05.2600.2180
Modem #0 Line Playback,0x00200000,1,0,quartz.dll,6.05.2600.2180
WDM Streaming System Devices:
MPU-401,0x00200000,3,2,,5.03.2600.2180
A: SB Live! MIDI Synth,0x00200000,11,2,,5.03.2600.2180
SB Live! Wave Device,0x00200000,13,2,,5.03.2600.2180
