RCU Forums - View Single Post - Priming on RC10GT?
Old 08-02-2005 | 04:04 PM
avg_joe's Avatar
avg_joe
Default RE: Priming on RC10GT?
Several easier ways...You could plug the exhaust stinger and turn the engine over until you see fuel get to the carb. You could install a tank w/primer button on it.(I don't recommend it, air leak) You could disconnect the fuel pressure line at the pipe, and blow into that until you see the fuel get to the carb. You could plug the stinger and pop the lid to the fuel tank a couple of dozen times.(but if dirt has collected around the lip, then you run the risk of dropping it into the fuel tank)
I use a starter box, and it is super easy for me to plug the stinger and spin the engine, but any of these methods will work.
