ORIGINAL: drumbum
I run a KOKAM 1500 mAh LiPo W/6v regulator and will fly 5 to 6 times at the field.. the next time i charge it on my triton it usually takes 185 or so mAh to top it. I fly about 15 min a flight.
Wow.
Part of the equation is the Mah, but another part of the equation that is overlooked is what the average voltage that a pack carries over a discharge. For instance if I have 2 six volt packs that I discharge and both say that have 1800 mah's of capacity but one says an average voltage of 6.2 volts and the other says 6.35 volts, which one will last longer?
