RCU Forums - View Single Post - Why not ground the block?
Old 08-02-2005 | 07:11 PM
kregan's Avatar
kregan
Default RE: Why not ground the block?
No, the pressure fit metal cup on the DA an many others are
the negative side of the ignition. The feed wire is in the center
of the cup/wire and it is shielded.
My question still stands... Besides the possibility of a loose connection
with a bolt, why would the manufactures rely on a pressure fit for the
ground/negative side of the plug?
For that matter why rely on a spring tension on the positive side when
the plug could have a bolt or nut to attach the positive wire?
ORIGINAL: Crusty
"As it stands now we only have a pressure fit around the spark plug
for the negative side of the ignition"
NO thats the +ve side
the engine is the earth side so you cant use it as the +ve feed
