RCU Forums - View Single Post - Replace gasket??
Old 08-02-2005 | 07:39 PM
Dave Shadel
Default RE: Replace gasket??
As long as the gasket doesn't leak you are OK, but if it leaks the engine will not run properly.
The 63 may need to be taken apart and the de-carboned after that many flights depending on the fuel you use. Sometimes the exhaust valve gets carbon buildup to the point of having problems.
How long since you changed the glow plug?
