RE: Why not ground the block?
When you use a CH ignition with the metal caps, 10mm or 14mm, there is a clamp to tighten so there is a postive lock on the plug. Seeing the number of rubber cap leads damaged by people in a hurry to get them off, I thing that they are tight enough.
