Larger engine
Why not pick up a 60-size trainer? If you go with the smaller one, you'll likely have to use some bigger wheels in order to get enough ground clearance for the prop. I think your older .61 will be at least a few ounces heavier than a modern .40. Most of them are well under 20oz with the muffler now.
