RE: FLUTTER problems flying the "U Can Do 3D"
Hi,
I want to tell you that I solve the problem. How? Very simple. I change the pushrods with other ones 3mm in diameter. I change the connection of pushrod to the surface from the outermost hole in the control horn to the one closer to the surface, the next one. Now the total travel of the surface is 45mm instead of the 57mm recommended by Greate Planes for 3D. And Finlay I used steel clevis of course.
