RCU Forums - View Single Post - Problems with the v-spec.
Old 08-03-2005 | 11:54 AM
Da Smak
Banned
Default RE: Problems with the v-spec.
If you've done all that and turned the MSN 1/4 (2/8ths to you) turn in. Then I feel there is an air leak from the most likely source. THE FRONT BEARING. I have had this problem you describe since sunday, but after swaping the front bearing, things are sweet and the mill which I had thought was just worn out, is now breathing again.
