RE: E-Flight hover
Im picking up the training gear (real stuff) this afternoon........... Is it just a much taller set of gear with balls on the end (and a wider stance?).......Question........ (for both of you)....... are all of your trims from factory and now just about centered? (other than throttle full down)?
Question......... where is your stock battery mounted........mid way on front skid, or, more like 75% behind the front skid? (mid way
seemed to be a bit nose heavy)
BTW...........It is durable.........hit full throttle by accident in a room, pulled back quick........slashed/marked the wall, minimal damage to rotor ends (very minimal).......... (this is why the cat is not allowed in the room at the same time) :-)
