RE: Stab and elevator size... need help!
Depending on what you want to with it, the numbers can be fudged. Go to the larger % for slow flying 3d type stuff where you need the larger size for the slow airflow over the surfaces. A pylon racer type can go for the lower end because of the higher speed and cutting down on drag for more speed.
