More than likely, the problems you are seeing with the two converted tailwheel trainers you are talking about are being caused by the main gear not being in the correct position. As far as not taking off properly because of a flat bottom airfoil, that has nothing to do with it. My LT40 has been in tailwheel configuration since day one, and I have never had any take off, or any other ground handling problems with it. The key to getting the thing to perform correctly is to get the main gear in the right place. If it's placed too far forward, or too far to the rear, yeah, it will handle like a nightmare. My gear is placed directly behind former #2 (I think this is the number for the former that is directly in from of the wing leading edge). I epoxied a 3 1/8" square piece of 1/8" birch aircraft ply on the fuselage floor, right behind the former, for reinforcement. My main gear is positioned so that the main wheels are just in front of the wing leading edge when the aircraft is sitting in a three point stance, and the wheels are DIRECTLY under the leading edge when it's up on the mains. If the owners of the planes you have mentioned would check their gear positioning and get them mounted correctly, I think the problems you have seen would disappear.
ORIGINAL: txaggie08
ima stick my nose in on the trainerr into a taildragger situation. i have seen nothing but mysery out fo the one flying at my field. they do not take off properly with the flatbottom airfoil. even my instructor(who is a pilot of well overa decades experience and is very good....), has hell with the alpha one huy is flying. another man that was a little ahead of me in training recently bought a nexstar that was converted....he does nothing but fight the thing on landings
