RE: FG BEETLE wont move
i wouldn't know without seeing it, but iv had the same kind of problem. Check the gear that sits on the back side of your engine connecting to your diff, the grub screws on the gear dont hold out very well, just tighten it back using some LOCTITE thread locker and you should be fine, to get to this gear you will need to dissmount the engine from the chassis. post back with your results n if that wasn't the answer then me or someone else on the large scale forum may be able to help you further. GOOD LUCK.
