RCU Forums - View Single Post - First build list - LT-40 + stuff
Old 08-03-2005 | 10:25 PM
  #31
somegeek's Avatar
somegeek
Default RE: First build list - LT-40 + stuff
Here's my list of stuff and where it sits...
Tower Hobbies order to show up early next week:
Sig LT-40 kit
Great Planes Dural Landing Gear Large .60
Sullivan Tailwheel Bracket 40-60 5-12 lbs.
3/8" Triangle stock for rear vertical stabilizer reinforcement
(3) APC 11x5 prop
Dave Brown Six Shooter Fuel Pump Glow & 3' of fuel tubing
2-56 Clevis
CA glue - thin
TH - x-acto blade set & saw w/ miter box
Sealing Iron
Iron sock
Hinge guide/hinge slotting machine
Still need to get:
Epoxy 15min or greater
2' strip of 2" wide glass
Debonder
Fuel jug cap tap
Sitting in the area I have cleared out for this build:
.46 OS AX
(2) A3 glow plugs(extra)
Futaba 6exa w/ (4) 3004 servos
Material for carbon fiber push rods
2.5"Aluminum Spinner w/ adapter
(1) APC 11x6 prop (for break-in per instructions)
Du-bro 12oz fuel tank
(2) Rolls Hangar 9 Ultracoat - Silver
(2) Rolls Hangar 9 Ultracoat - Corsair Blue
6" x 12" 1/4 ply - guide material for push rods
8 oz bottle of Tite bond II
2 ft of fuel line
2 feet of large fuel line for gas can
Alcohol for Epoxy thinning(fuel proofing)
Sandpaper 100 & 220 grit
Sanding bars 100 & 220 grit
Single edge razors (100ct pack)
Heat gun
Ceiling Tile (working/pinning surface)
T-pins
Plastic clothes pins
Wax paper for working surface when gluing
Fuel - 15% nitro with 18% oil will be just fine, 20% oil will be better)
Du-bro Kwik start XL glow starter
Regarding the radio... rechargable battery packs included? The trim switches? The whole fact that it's computerized? Damn! Radios have come a long way since I was last into RCs. My last radio had long trim sliders for each axis and took a grip of AAs that you had to pull out to recharge.
My plane kit should show up early next week... gonna document my build in a thread. Can't wait!!
somegeek
