RE: Yak 54 .40-.50 ARF need help with pull-pull elevator setup
I'll be more then happy to help you with this thread. I've got hundreds of flights on mine now. The people that have been crying and whining about the plane just either don't know how to fly or think it's going to be super light 3D plane. It's not ... it's a scale plane that will outfly circles around anything in it's class.
Everything I used was stock. You'll get a TON of throw from the split elevators, don't worry about putting pull pull on them.
One important tip about the elevator. Low rate 1/4", High rate 3/4". When you find a good low rate then you can max out your high rate. This is just so you have 2 safe buffer zones. You find the best low rate when you do straight and level and pull elevator with no snaps.
I've subscribed to this post so if you need anything just ask.
