RCU Forums - View Single Post - VENTURI SIZE vs ENGINE SPEED
Old 08-04-2005 | 10:46 AM
2BFlying
Default RE: VENTURI SIZE vs ENGINE SPEED
thanks for the reply
I can turn out venturis about every 2 minutes on the lathe, my program will make all of them the same and all I have to do is change the bore size. I have a starting point and will work down from there.
I'm sure I don't want to go larger and I have the G-51 needle valve which is about the .156 you described.
thanks
