RE: Another Ryobi Question.
Clamp the flywheel lightly in a vise and turn off the clutch with a pair of channel lock pliers. Use a gear puller to remove the flywheel or pry it frmm side to side with a large flat screw driver. The mag ignition is fine. Careful not to loose the key if it is not cast into the wheel. Buy a longshaft kit from Wackerengines.com. Buy a resister plug at your auto parts store.
Dave
