RE: Honeybee2 TX modification question
ya gotta do surgury. you have to open the radio.. and I have read numerous way's of doing it. some like it with a piece of gas hose across the metal tab some just remove the tab alltogether.. but it makes the stick too sloppy.. I personally took a dremel to the quarter moon on the backside of the stick and buzzed it off with a puny stone.. as fluid as possible one swipe.. then replaced the tab. I had experimented with putting more tension on the tab but it fealt best just stock pressure.. once ya do it tho.. you cant go back '_;
