RCU Forums - View Single Post - prop size?
Thread: prop size?
Old 08-05-2005 | 06:43 AM
MikDee
Default RE: prop size?
Try the stock prop, if it runs too hot, get a smaller one, if not get an X435, or X535, (both are 35mm- 535 has more pitch but may run hotter) Generally 35 mm is the biggest diameter you should run on a submerged prop. Let us know how you make out.
