RCU Forums - View Single Post - Needle valve to Carb fuel line arch...
Old 08-05-2005 | 06:53 AM
rwright142's Avatar
rwright142
Default RE: Needle valve to Carb fuel line arch...
As short as possible but make sure it does not rub the engine or you will have wear and eventually a hole. Also, make sure that any vibration does not cause it to rub the engine.
