RCU Forums - View Single Post - Taildragger ground handling?
Old 10-28-2002 | 06:02 PM
ptgarcia's Avatar
ptgarcia
My Feedback: (36)
Default Taildragger ground handling?
I converted my H9 Xtra Easy trainer from tricycle gear to tail dragger last week and flew it for the first time this weekend. On my first attempt at taking off, I started to get a little "squirly" and had to back off the throttle, taxi back to the beginning of the runway and try it again. The 2nd attempt was perfect. I held up elevator and a little right rudder and eased on the throttle. Once I gained a little speed I let off the elevator, allowed the tail to come up off the ground, picked up enough speed to lift off, fed in up elevator, and slowly gained altitude.
I have to say it looks so much cooler with the tail wheel set-up. Anyway, good luck. With a little practice you'll have no problem at all.
