RE: prop size?
Thanks MikDee. I have a 36mm with the same 1.6 pitch as stock coming and also a 36mm 3 blade with 1.4 pitch. I hope one of those will do the trick. So far heat has not been a problem after I made a new pick up. Now the motor never gets over 72 degrees even after several packs running wide open.
